show licenses
show licenses {[slot slot |all]} {detail}
Description
Displays current software license level, port speed licensing, and feature packs enabled on your switches.
Syntax Description
all Specifies all slots on a stack.
slot Specifies one or more slots on a stack.
detail Specifies showing detailed license information. ExtremeSwitching Universal switches only.
Default
N/A.
Usage Guidelines
The command displays information on the software license level and feature packs enabled on the switch or nodes on a stack, including the trial license or factory default license and days left to expiry.
To see the license information on a SummitStack node, run the command while logged into that node.
See the specific chapter of the Switch Engine v33.1.1 User Guide that discusses each feature to determine if a license is required for some functionality. If not noted, all functionality is available, and license is not required.
For ExtremeSwitching Universal switches, the DEF-EVAL-PRMR is a 30-day evaluation license that is enabled on the switch from the factory, or after changing the network operating to Switch Engine from Fabric Engine, or after a rescue boot.
The following command displays the license level configuration:
show licenses
On a SummitStack, the output from this command looks similar to the following:
Slot-3 Stack.12 > show licenses
Enabled License Level:
Advanced Edge
Enabled Feature Packs:
None
Effective License Level:Edge
The show output also includes the current status of the non-Extreme optical device license:
# show license
        Advanced Core
        MPLS ServiceProviderEdge  3rdPartyOptics
To see all license levels on a stack:
Slot-1 Stack.6 # show licenses slot all
 Slot Enabled License          Effective License        Feature Packs
 1    Advanced Edge            Advanced Edge            DirectAttach
 2    Advanced Edge            Advanced Edge            ServiceProviderEdge
                                                        DirectAttach
                                                        NetworkTiming
To view detailed license information on the ExtremeSwitching Universal switches:
# show licenses detail
Slot  License Product     Feature(s)  Installed   Effective   Expiration
1     DEF-EVAL-PRMR       Premier     Yes         No          Mon Sep 14 12:41:22 2020
1     PRD-5000-MACSEC     MACsec      No          N/A         N/A
2     PRD-5000-PRMR       Premier     No          N/A         N/A
2     PRD-5000-MACSEC     MACsec      Yes         N/A         Never
3     PRD-5000-PRMR       Premier     No          N/A         N/A
3     PRD-5000-MACSEC     MACsec      No          N/A         N/A
This command was first available in ExtremeXOS 11.1.
The information on enabled feature packs was added in ExtremeXOS 11.4.
The information on the trial licenses was added in ExtremeXOS 11.6.
The show output was updated to include the current status of the non-Extreme optical device license in ExtremeXOS 15.4.
The options all and slot were added in ExtremeXOS 22.5.
The detail option and ExtremeSwitching unified license information was added in ExtremeXOS 31.1.
Platform Availability
